priffe Posted September 20, 2018 Report Share Posted September 20, 2018 (edited) Tänkte jag dumpar lite allmän info här som alla kanske inte har Edited September 20, 2018 by priffe 1 Quote Link to comment Share on other sites More sharing options...
priffe Posted September 20, 2018 Author Report Share Posted September 20, 2018 1984 - 1990 * Production period in Japan. The period of introduction for this generation model may vary by region. BJ70 BJ70V BJ70V LX DIMENSIONS Overall, length 3,975mm Overall, width 1,690mm Overall, height 1,870mm Wheelbase 2,310mm Tread, front 1,425mm Tread, rear 1,420mm Ground clearance 185mm Seating capacity 5) Passengers Turning radius 5.3m WEIGHT Net vehicle weight- 1,790kg Gross vehicle weight 2,300kg Payload 400(0)kg ENGINE Type Model 3B, diesel engine, OHV Cylinders in-line 4 Bore x stroke 102.0 x 105.0mm Displacement 3.431cc Compression ratio 20.0 Maximum net power 98PS/3,500 r.p.m. Maximum net torque 23.0kg-m/2,200 r.p.m. Gasolin tank capacity 90 liters TRANSMISSION 5 M/T Gear ratio : 1st 4.843 : 2nd 2.618 : 3rd 1.516 : 4th 1.000 : 5th 0.845 : reverse 4.843 TRANSFER Gear ratio : high 1.000 : low 1.960 Axle ratio 4.111 SUSPENSION Front semi-elliptic leaf spring Rear semi-elliptic leaf spring STEERING GEAR ball-and-nut BRAKE Front disc Rear drum TIRE 215SR15 BJ73V LX DIMENSIONS Overall, length 4.265mm Overall, width 1,690mm Overall, height 1,915mm Wheelbase 2,600mm Tread, front 1,425mm Tread, rear 1,420mm Ground clearance 210mm Seating capacity 2 (5) Passengers Turning radius 5.3m WEIGHT Net vehicle weight 1,830kg Gross vehicle weight 2,340kg Payload 400(250)kg ENGINE Type Model 3B, diesel engine, OHV Cylinders in-line 4 Bore x stroke 102.0 x 105.0mm Displacement 3.431cc Compression ratio 20.0 Maximum net power 98PS/3,500 r.p.m. Maximum net torque 23.0kg-m/2,200 r.p.m. Gasolin tank capacity 90 liters TRANSMISSION 5 M/T Gear ratio : 1st 4.843 : 2nd 2.618 : 3rd 1.516 : 4th 1.000 : 5th 0.845 : reverse 4.843 TRANSFER Gear ratio : high 1.000 : low 1.963 Axle ratio 4.111 SUSPENSION Front semi-elliptic leaf spring Rear semi-elliptic leaf spring STEERING GEAR ball-and-nut BRAKE Front disc Rear drum TIRE 215SR15 BJ71V LX DIMENSIONS Overall, length 3,975mm Overall, width 1,690mm Overall, height 1,870mm Wheelbase 2,310mm Tread, front 1,425mm Tread, rear 1,420mm Ground clearance 185mm Seating capacity 2 (5) Passengers Turning radius 5.3m WEIGHT Net vehicle weight 1,820kg Gross vehicle weight 2,330kg Payload 400(0)kg ENGINE Type Model 13B-T, diesel engine, OHV,turbo Cylinders in-line 4 Bore x stroke 102.0 x 105.0mm Displacement 3,431cc Compression ratio 17.6 Maximum net power 120PS/3,400 r.p.m. Maximum net torque 29.0kg-m/2,000 r.p.m. Fuel Tank Capacity 90 liters TRANSMISSION 5 M/T Gear ratio : 1st 4.843 : 2nd 2.618 : 3rd 1.516 : 4th 1.000 : 5th 0.845 : reverse 4.843 TRANSFER Gear ratio : high 1.000 : low 1.963 Axle ratio 4.111 SUSPENSION Front semi-elliptic leaf spring Rear semi-elliptic leaf spring STEERING GEAR ball-and-nut BRAKE Front disc Rear drum TIRE 215SR15 BJ74V LX DIMENSIONS Overall, length 4,265mm Overall, width 1,690mm Overall, height 1,915mm Wheelbase 2,600mm Tread, front 1,425mm Tread, rear 1,420mm Ground clearance 185mm Seating capacity 2 (5) Passengers Turning radius 5.8m WEIGHT Net vehicle weight 1,870kg Gross vehicle weight 2,380kg Payload 400(250)kg ENGINE Type Model 13B-T, diesel engine, OHV,turbo Cylinders in-line 4 Bore and stroke 102.0 x 105.0mm Displacement 3,431cc Compression ratio 17.6 Maximum net power 120PS/3,400 r.p.m. Maximum net torque 29.0kg-m/2,000 r.p.m. Gasolin tank capacity 90 liters TRANSMISSION 5 M/T Gear ratio : 1st 4.313 : 2nd 2.330 : 3rd 1.436 : 4th 1.000 : 5th 0.838 : reverse 4.220 TRANSFER CASE Gear ratio : high 1.000 : low 2.295 Axle ratio 4.875 SUSPENSION Front semi-elliptic leaf spring Rear semi-elliptic leaf spring STEERING GEAR ball-and-nut BRAKE Front ventilated disc Rear drum TIRE 215SR15 1990 - * Production period in Japan. The period of introduction for this generation model may vary by region. HZJ77HV HZJ73HV HZJ77HV ZX DIMENSIONS Overall, length 4,805mm Overall, width 1,790mm Overall, height 1,935mm Wheelbase 2,730mm Tread, front 1,455mm Tread, rear 1,440mm Ground clearance 215mm Seating capacity 2 (5) Passengers Turning radius 6.1m WEIGHT Net vehicle weight 2,130kg Gross vehicle weight 2,640kg Payload 400(250)kg ENGINE Type Model 1HZ, diesel engine, OHC Cylinders in-line 6 Bore x stroke 94.0 x 100.0mm Displacement 4,163cc Compression ratio 22.7 Maximum net power 135PS/4,000 r.p.m. Maximum net torque 28.5kg-m/2,200 r.p.m. Fuel Tank Capacity 90 liters TRANSMISSION 4 A/T Gear ratio : 1st 2.950 : 2nd 1.530 : 3rd 1.000 : 4th 0.717 : reverse 2.678 TRANSFER Gear ratio : high 1.000 : low 2.295 Axle ratio 4.111 SUSPENSION Front semi-elliptic leaf spring Rear semi-elliptic leaf spring STEERING GEAR ball-and-nut BRAKE Front ventilated disc Rear ventilated disc TIRE 31 x 10.5R15 HZJ73HV ZX DIMENSIONS Overall, length 4,455mm Overall, width 1,790mm Overall, height 1,950mm Wheelbase 2,600mm Tread, front 1,455mm Tread, rear 1,440mm Ground clearance 215mm Seating capacity 2 (5) Passengers Turning radius 5.8m WEIGHT Net vehicle weight 2,020kg Gross vehicle weight 2,530kg Payload 400(250)kg ENGINE Type Model 1HZ, diesel engine, OHC Cylinders in-line 6 Bore and stroke 94.0 x 100.0mm Displacement 4,163cc Compression ratio 22.7 Maximum net power 135PS/4,000 r.p.m. Maximum net torque 28.5kg-m/2,200 r.p.m. Fuel Tank Capacity 90 liters TRANSMISSION 5 M/T Gear ratio : 1st 4.843 : 2nd 2.618 : 3rd 1.516 : 4th 1.000 : 5th 0.845 : reverse 4.843 TRANSFER Gear ratio : high 1.000 : low 1.963 Axle ratio 4.111 SUSPENSION Front semi-elliptic leaf spring Rear semi-elliptic leaf spring STEERING GEAR ball-and-nut BRAKE Front ventilated disc Rear ventilated disc TIRE 31 x 10.5R15 PZJ77V LX DIMENSIONS Overall, length 4,685mm Overall, width 1,690mm Overall, height 1,900mm Wheelbase 2,730mm Tread, front 1,415mm Tread, rear 1,410mm Ground clearance 200mm Seating capacity 2 (5) Passengers Turning radius 6.1m WEIGHT Net vehicle weight 1,590kg Gross vehicle weight 2,460kg Payload 400(250)kg ENGINE Type Model 1PZ, diesel engine, OHC Cylinders in-line 5 Bore and stroke 94.0 x 100.0mm Displacement 3,469cc Compression ratio 22.7 Maximum net power 115PS/4,000 r.p.m. Maximum net torque 23.5kg-m/2,600 r.p.m. Fuel Tank Capacity 90 liters TRANSMISSION 5 M/T Gear ratio : 1st 4.313 : 2nd 2.330 : 3rd 1.436 : 4th 1.000 : 5th 0.838 : reverse 4.220 TRANSFER Gear ratio : high 1.000 : low 1.963 Axle ratio 4.111 SUSPENSION Front semi-elliptic leaf spring Rear semi-elliptic leaf spring STEERING GEAR ball-and-nut BRAKE Front ventilated disc Rear drum TIRE 215/80R16 PZJ70V STD DIMENSIONS Overall, length 4,045mm Overall, width 1,690mm Overall, height 1,885mm Wheelbase 2,310mm Tread, front 1,415mm Tread, rear 1,410mm Ground clearance 200mm Seating capacity 2 (5) Passengers Turning radius 5.3m WEIGHT Net vehicle weight 1,790kg Gross vehicle weight 2,300kg Payload 400(0)kg ENGINE Type Model 1PZ, diesel engine, OHC Cylinders in-line 5 Bore and stroke 94.0 x 100.0mm Displacement 3,469cc Compression ratio 22.7 Maximum net power 115PS/4,000 r.p.m. Maximum net torque 23.5kg-m/2,600 r.p.m. Fuel Tank Capacity 90 liters TRANSMISSION 5 M/T Gear ratio : 1st 4.313 : 2nd 2.330 : 3rd 1.436 : 4th 1.000 : 5th 0.838 : reverse 4.220 TRANSFER Gear ratio : high 1.000 : low 1.963 Axle ratio 4.111 SUSPENSION Front semi-elliptic leaf spring Rear semi-elliptic leaf spring STEERING GEAR ball-and-nut BRAKE Front ventilated disc Rear drum TIRE 215/80R16 1985 - 1996 * Production period in Japan. The period of introduction for this generation model may vary by region. LJ71G KZJ71G KZJ78W LJ71G WAGON DIMENSIONS Overall, length 3,975mm Overall, width 1,690mm Overall, height 1,865mm Wheelbase 2,310mm Tread, front 1,425mm Tread, rear 1,420mm Ground clearance 205mm Seating capacity 5 Passengers Turning radius 5.3m WEIGHT Net vehicle weight 1,680kg Gross vehicle weight 1,955kg ENGINE Type Model 2L-T, diesel engine, turbo Cylinders in-line 4 Bore and stroke 92.0 x 92.0mm Displacement 2,446cc Compression ratio 20.0 Maximum net power 85PS/4,000 r.p.m. Maximum net torque 19.2kg-m2,400 r.p.m. Fuel Tank Capacity 90 liters TRANSMISSION 5 M/T Gear ratio : 1st 4.313 : 2nd 2.330 : 3rd 1.436 : 4th 1.000 : 5th 0.838 : reverse 4.220 TRANSFER Gear ratio : high 1.000 : low 2.295 Axle ratio 4.875 SUSPENSION Front trailing type, rigid axle with coil springs Rear trailing type, rigid axle with coil springs STEERING GEAR ball-and-nut BRAKE Front disc Rear drum TIRE 215/SR15 LJ78G PRADO EX5 DIMENSIONS Overall, length 4,585mm Overall, width 1,690mm Overall, height 1,905mm Wheelbase 2,730mm Tread, front 1,415mm Tread, rear 1,415mm Ground clearance 205mm Seating capacity 8 Passengers Turning radius 6.1m WEIGHT Net vehicle weight 1,920kg Gross vehicle weight 2,360kg ENGINE Type Model 2L-TE, diesel engine, turbo Cylinders in-line 4 Bore and stroke 92.0 x 92.0mm Displacement 2,446cc Compression ratio 21.0 Maximum net power 97PS/3,800 r.p.m. Maximum net torque 24.5kg-m/2,400 r.p.m. Fuel Tank Capacity 90 liters TRANSMISSION 4 A/T Gear ratio : 1st 2.804 : 2nd 1.531 : 3rd 1.000 : 4th 0.753 : reverse 2.393 TRANSFER Gear ratio : high 1.000 : low 2.295 Axle ratio 4.875 SUSPENSION Front trailing type, rigid axle with coil springs Rear trailing type, rigid axle with coil springs STEERING GEAR ball-and-nut BRAKE Front ventilated disc Rear ventilated disc TIRE 215/80R16 KZJ71W PRADO SX WIDE DIMENSIONS Overall, length 3,975mm Overall, width 1,790mm Overall, height 1,880mm Wheelbase 2,310mm Tread, front 1,455mm Tread, rear 1,455mm Ground clearance 200mm Seating capacity 5 Passengers Turning radius 5.3m WEIGHT Net vehicle weight 1,780kg Gross vehicle weight 2,055kg ENGINE Type Model 1KZ-TE, diesel engine, turbo Cylinders in-line 4 Bore and stroke 96.0 x 103.0mm Displacement 2,982cc Compression ratio 21.2 Maximum net power 130PS/3,600 r.p.m. Maximum net torque 29.5kg-m/2,000 r.p.m. Fuel Tank Capacity 90 liters TRANSMISSION 4 A/T Gear ratio : 1st 2.804 : 2nd 1.531 : 3rd 1.000 : 4th 0.753 : reverse 2.393 TRANSFER Gear ratio : high 1.000 : low 2.295 Axle ratio 4.300 SUSPENSION Front trailing type, rigid axle with coil springs Rear trailing type, rigid axle with coil springs STEERING GEAR ball-and-nut BRAKE Front ventilated disc Rear ventilated disc TIRE 265/70R15 KZJ78W PRADO SX WIDE DIMENSIONS Overall, length 4,615mm Overall, width 1,790mm Overall, height 1,885mm Wheelbase 2,730mm Tread, front 1,455mm Tread, rear 1,455mm Ground clearance 200mm Seating capacity 8 Passengers Turning radius 6.1m WEIGHT Net vehicle weight 1,930kg Gross vehicle weight 2,370kg ENGINE Type Model 1KZ-TE, diesel engine, turbo Cylinders in-line 4 Bore and stroke 96.0 x 103.0mm Displacement 2,982cc Compression ratio 21.2 Maximum net power 130PS/3,600 r.p.m. Maximum net torque 29.5kg-m/2,000 r.p.m. Fuel Tank Capacity 90 liters TRANSMISSION 4 A/T Gear ratio : 1st 2.804 : 2nd 1.531 : 3rd 1.000 : 4th 0.753 : reverse 2.393 TRANSFER Gear ratio : high 1.000 : low 2.295 Axle ratio 4.300 SUSPENSION Front trailing type, rigid axle with coil springs Rear trailing type, rigid axle with coil springs STEERING GEAR ball-and-nut BRAKE Front ventilated disc Rear ventilated disc TIRE 265/70R15 2 Quote Link to comment Share on other sites More sharing options...
Klydd Posted September 20, 2018 Report Share Posted September 20, 2018 haha du vann lätt "längsta posten" Men, bra med info! ? 1 Quote Link to comment Share on other sites More sharing options...
