Diesel pump repair workshop
DaveN
Hello
There are several garages in the area but do they have a blank plate to a Toyota pump.
The question is if you are not obliged to manufacture one?
Why should you pick off a ACSD ?
JAK
Hello
JAK
Thanks mate. The plates are usually fitted to many Denso and Bosch pumps when they are shipped, to cover switch/sensor holes. They get thrown away when the pump is fitted to a vehicle. The ACSD is rattling, and they've been known to break up and bits fall into the pump, wrecking it. So I thought I'd get rid of it before it breaks.
Ok I understand. Let me check with some.
